How do you modify a BB ? Use a spacer ?JmZ said:Name your price and durability.
Last ones I knew of...
Action Tec (at Cambria)
Phil Wood
Token??? (I don't know if they are ISO or JIS though)
Might also look at taking a 68 and modifying it. Then might even be able to look at SINZ or the like for Euro Ti BMX BB's.
Or take a look on E-Bay for the older Race Face Taperloc Ti's.
Good luck,
JmZ
Can the bearing be removedCheers! said:Phil Wood
Only very old school cranks use such wide BBs (120mm). That's why i suggested he might try a shorter spindle. All that counts is that the chainrings clear the chainstays. there's absolutely no need to have a wide BB when shorter ones fit as well. Long axles not only add weight but make for a large q-factor and on square BBs the longer the axle the more flex. Especially long Ti-axles suffer in this aspect. Remember - square BBs are already flexiest when compared with other BBs (ISIS, Octalink and actual integrated designs). This flex will make for additional load on the bearings which results in shorter life...Flystagg said:That would depend on the cranks, if the crankset is desinged for 113 with a triple, the 103 would be perfect for 2X9, but probably not a good idea if the cranks were designed for a 120+mm bb, then 113 is good.
Now this is where I get a bit confused.nino said:are you sure you need 113mm?
That's rather wide and makes for a large q-factor. Usually you should be fine with 107mm.
I personally used even a short 103mm with triple rings up front on my Scott Scale which also has 73mm BB shell. Now with my 2x9 setup 103 is a must.
you are right. if you use the inner positions you need a slightly wider axle to get the chainrings in proper position.BruceBrown said:Now this is where I get a bit confused.
Let's say I wanted to convert a square taper Race Face Next LP standard BCD (110/74) crankset from a triple to a 2 x 9 using the granny holes for the small ring and the middle for the large ring on a frame that takes a 68x113mm bb. Case in point being trying out the 2 x 9 Q rings on a Race Face 110/74 Next LP set.
Wouldn't I want to "push" the rings out on the drive side a bit for a much better chainline (like Middleburn Duo for instance) where the granny of a 2x9 sits a bit further out than on a triple and the large ring of a 2x9 sits a bit in from a triple? I thought one would use spindle length to accomplish this - especially to be able to utilize all the gears (twist shift a must to trim the front derailleur). I've got an old Taperlock 68/73 x 110 sitting around with adjustable chainline that I thought would be great for a Race Face Next conversion.
Are you saying that to go 2 x 9 I would need to go shorter on the spindle length? I could see that if one was running the 2x9 on the middle and large ring slots of a triple crank as you would need to pull the rings in closer to the frame for better chainline, but if using the inner two ring slots - don't I want to push them out away from the bb shell a bit? Q-factor aside, I want a set up that shifts and utilizes all the gears.
Just curious and confused...
BB
Exact same setup here. RF Next LP + TA specialities ti axix pro. Raced it for a full summer, stiff as can be.rasmusj said:I have the TA Axis on my Race Face Next cranks, it comes in both ISO and JIS afaik. Has been running great so far, weight is as advertised, has removable bearings.
I am using some NEXT LP (surprisingly heavy @ 426gr) with 29t x 42t (94mm bcd).Flystagg said:yup 103mm spindle on my rf turbines with 29 42 tooth, q-factor was around 153mm, and I could use any gear combo.
