Myself and I believe a few others have been talking to Mark at Cutters about the seven up boards with a driver on board .
This I think will make Certainly my light smaller and better to handle the thermal load the 7 up presents and a whole lot easier to build .
Here is a copy of a mail just in from Mark showing the Specs of this soon to be available board , I can see it being a winner :thumbsup:
Hi Chris
Something to wet the whistle
Still getting the track work done for the Seven. Its looking good though nearly done.
the triple will need some work to get it in to the space.
Specs for the seven.
Two modes all 7 or 3 central in a row. set by briefly interrupting the power.
Can run up to 1000mA per XPG (this would be close to the max but you can specify a reasonable range when ordering)
Thermal regulation with dimming at 80C as per most of my designs.
11 to 20V operation (subject to sample testing)
8V operation at reduced power level (4 LED operating)
Same physical diameter as optic with space for two M3 mounting holes.
Customisation is available but I think we should talk about MOQ on custom jobs.
This would include but is not limited to:-
Under voltage shut down or reduced power mode.
Voltage warning with a blink.
Different power levels.
Flash modes.
A Red/Blue police/emergency version (often referred to as a wig/wag) With appropriate flashing mode.
Amber warning version.
And I believe there to be a redesign of their single board to accomadate the Regina Reflector And this one I am also keen to get hold of some :yesnod:
Hi Chris
Flash modes.
