The surly 1x1 has track fork ends correct? This means I will not need a chain tensioner correct, and to sort the tension via sliding the wheel backwards and forwards? Will I still be able to run disc brakes on this bike with no hassles when changing wheels?
If I get a frame with horizontal or vertical dropouts I will need a chain tensioner yes?
Should I look at a frame with an EBB or without?
I am wanting to fit disc brakes to my new build that I am trying to plan. I guess importantly I am wanting to create something that is simple and not so complicated when changing wheels, trying to avoid the need for tensioners, etc... one reason for getting away from gears... you want to see me trying to remove my rear wheel with gears... it is a scream i tell you.
I am looking at the surly 1x1 and the soma 4one5 at the moment as frame options. Builds such as the Independent Fabrication single speed frames appear to have vertical dropouts with EBB.
Looked through the FAQ section, but I am super new to all of this and it bangles with my 2 brain cells at times...
forgive me?
forgive me?
