I've had to deal with it a couple of times in the past, and it's reared its ugly head again today.
Problem #1: Bought a used Ford Ranger after college (my first car that I'd actually bought myself). after I bought it, I took it in to get my fluids changed because I just didn't know when the last time those things had been done. shop (one of those chain tire/tune/lube type shops) put f'n gearbox fluid in the manual transmission instead of Ford's special tranny fluid. Shifter was almost impossible to shift. I had to limp around in 1st or 2nd gear. Specialized tranny shop told me 1st and 2nd gears needed replacing and I scoffed at them. Took the truck to a Ford dealer who discovered the problem. I had the shop who f'd things up pay my bill with the dealer.
Problem #2: That same Ranger kept having persistent problems with the parking brake cable getting moisture in it and rusting/freezing/seizing on an annual basis. Shops (including the dealer) were more than happy to fix my burned up brakes and the cable, but nobody was willing to take the extra step to find out WHY I was having these persistent problems.
Problem #3: Fast forward to last year, my 07 Honda Fit I bought new was having a clunking noise when I drove over certain bumps in the road. It didn't happen on all bumps, but there were a couple where I could replicate the issue EVERY time. I took the car to a mechanic I trust, and he discovered that one of my brake caliper bolts was missing and the other (on the same caliper) was loose. WTF? I haven't had any actual brake work done, but I have had some annual inspections done over the years. Srsly?
Problem #4: About 2 months after I bought the Fit in PA, the car got nailed by a shopping cart in a parking lot. I had the car in to get the door repainted. After I moved to TX, I noticed that the car got water on the floor in the backseat after a particularly intense storm that flooded a lot of streets locally. I cleaned it up and kept an eye on it. I had no problems until just recently, when I noticed a little bit of mildew (and some ice) back there when I was cleaning out the car. I usually keep the back seats folded down, so don't notice things immediately. At any rate, the car was due for some service, so I had my local mechanic take a look at it when he had the car on the lift. He didn't see anything obvious and suggested I take it to the dealer because I'm still under warranty. The dealer is a bit of a drive from me, so that finally gave me the incentive to make an appointment (I also needed to get a minor recall taken care of).
Today was my appointment day, and they checked everything. First thing they looked at was my roof rack - it's not causing any leaks. Then they checked all the door seals and did some testing - nada. Then they started pulling carpet and trim from the interior. They started at the back where the water was pooling and radiated outward from there. They checked my windshield because I had it replaced once (rock on the freeway cracked it). They checked to see if my windshield wiper fluid line was intact (someone had a mouse-chewed line recently that was getting washer fluid in the car). They checked to see if the condensation drain on the a/c was plugged up. All of those things were fine. They were doing some water testing around that passenger door I had repainted 3 1/2 yrs ago and saw some water dripping out from the INSIDE of the door. Hmmmm.... So they tore off the door panel to see what was going on...and they found my leak. First thing he asked me was if someone has done any work there. Well, as a matter of fact, I once had the entire door stripped to bare metal and repainted. Oh really? Well there's a plastic cover inside the door that's supposed to be sealed up, and it keeps water that gets inside the door from getting inside the car. Well, the entire bottom half of that plastic sheet wasn't even sealed on. There was even water on my speaker in that door.
Looks like tomorrow I get to call the shop that did that work and tell them that they owe me $200 for fixing their shoddy work. That should be fun, because I had that work done 3.5ish years ago. And I probably never would have found it if I didn't live in a place where rainstorms that drop several inches of rain at a time weren't relatively common this time of year.
