1 - 5 of 5 Posts
I'm looking to purchase a set of XC disc wheels, rims <400g, total set 1500g about. I was thinking of Stan's Olympic ZTR's or Mavic 517's with Hugi 240s or WTB Laser Lites, which sounds expensive! Then I saw www.spinlitecycling.com selling Velocity brand wheels at much less.
The hubs are $54 / $85, weight comparable to XTR. Wheels built with Velocity hubs, Mavic 517's and Sapim Laser 14/17 spokes come in at 1518g - pretty good! - and are super cheap at $271.00.
I know the golden rule ... you only get 2 out of 3 on bike parts (quality / cheap / light), but I'm hoping ...
Anybody have experience with Velocity products? You input is much appreciated!
Premium Member
I do not see that those wheels use disc brake hubs. The only Velocity hubs on the site a not disc. The Lazer spokes and X517 rims are also not good choices for disc wheels.
No good in rock gardens..
Velocity
The Aero Heat rim is 440 grams, and from memory not eyeletted. A friend had a purple set (yes, purple) on his GT hardtail. I have a set of K525 rims on my Klein Pinnacle, these rims are sadly no longer made. They were 22mm wide with a V section and not eyeletted. They were 385 grams and plenty strong enough for XC.
http://www.velocitywheels.com/MTB_rims.htm
Discussion Starter · #4 ·
Thanks for your reply, Shiggy. I was actually considering getting SpinLite to swap the hubs (there is disc version on their hubs page). What makes the X517 rim and Lazer spokes a poor choice for disc braking? (I ride disc for wet conditions, long descents and because my frame only has disc posts, not because I'm doing big drops)
CanuckXC.
Premium Member
CanuckXC.
I see the disc version now. They WILL be heavier (~150?).
The X517 was notorious for cracking at the eyelets even with rim brakes. Discs add to the stress.
Lasers (same dimensions as the DT Revolutions) are just too thin/light/elastic for disc wheels under most riders. Few custom builders will use them.
1 - 5 of 5 Posts
