Velocity VXC max tire size.....2.35?
746 Views 2 Replies 2 Participants Last post by  spacoli
Just wondering if I could use a Nevegal 2.35 on my VXC rims without any mounting or performance problems?
I would be using no tubes with them.
Any info would be helpful, thanks.
1 - 3 of 3 Posts
VXC rims are not designed to be used without inner tubes.
I have run 2.6" tires on the VXC and regularly use 2.3-2.5 tires on them - with tubes.
Wide tires on narrow rims does affect the performance. Whether it is a good or bad affect depends on your riding style and personal preferences. I happen to like it.
I do understand.....thanks shig
Thanks shig, I currently have 2.0 tire on the rims and find that I'm wanting more protection for the rim, as I don't want to dent it bad with the lower tire pressure and the faster harder riding I'm doing.
I understand that any rim that is not UST is not to be used with out a tube. I have never used the VXC with tubes so I can't say what the difference would be. I converted them over with stan's right away. They have held air great and currently have four holes that have been sealed. There is four flat changes that I have avoided. I don't think I will ever go back to tubes.
1 - 3 of 3 Posts
