Go with a Bontrager Rhythm tubeless rim strip in your Blunts. It snaps right in like it was made for the Blunt and setting up your tires tubeless will be really easy. Make sure you align the valve holes upon installation though, if you go this route.Dirt Dude said:Call Velocity and talk to Jeff. He's VERY knowledged on these and can direct you the way to go.
The way he discussed with me was to go with teh Blunts for XC style stuff. They can be changed to Tubeless in case you compete. The P35s are more for All Mountain styled stuff and are wider. I think he stated the Blunts were 28mm wide and the P35s were 35mm wide...
I am going with the Blunts for the chance to possibly go tubeless with them...
It's true, they aren't eyeletted, but I've built and ridden non-eyeletted Velocity rims in the past without trouble, and I think Velocity's reputation stands behind their choice.Vermont29er said:It appears that these rims don't have spoke eyelets. Could that be a problem?
How long have you had them? I'm curious to how they hold up to drops. My old Velocity 26" Aeroheats could take some serious abuse. I'm hoping that these can take the same.Speedub.Nate said:It's true, they aren't eyeletted, but I've built and ridden non-eyeletted Velocity rims in the past without trouble, and I think Velocity's reputation stands behind their choice.
Admittedly, I'd rather have eyelets if given the option, but it didn't stop me from buying this rim.
Know what? I misspoke. I built one non-eyeletted Aeroheat into a front wheel, that went from Joshua to NRS to Hollowpoint over about a 5 year span. I never had an issue with it. But I'm not a huckster -- this was all XC with at most some 2' drops.dubthang said:How long have you had them? I'm curious to how they hold up to drops. My old Velocity 26" Aeroheats could take some serious abuse. I'm hoping that these can take the same.
Good point.Guitar Ted said:... eyelets are no guarantee of having no spoke hole failures ... I've seen lots of eyeleted rims fail at the spoke holes.
Apparently Stan's is making a roll with a width of 32mm and this is what Velocity is recommending for the P-35.jdusto said:Which size of Stan's Rim Strip do you use? I see sizes for 27-34mm and 36-39mm but not one which covers 35mm.
really? with the blunts or the P35's? right now I'm running the blunts with the velo plugs (you can get them all over on the web by the way) wanted tubeless but hate the whole rim strip crap to convert. you got the plug to seal without something over them? would LOVE to get rid of the super heavy slime tubes!!! just don't see those plugs sealing..nolan17 said:I used the Velocity Veloplugs with a Stans valve, no strip needed. They mounted up tubless with a Conti Mountain King no problem.
In order to get the Veloplugs you have to order the rims as well.
Sweet! Did you do the build yourself? If not, who built them?pooman320 said:
