1 - 13 of 13 Posts
Discussion Starter #1
Just fitted the velocity rims with a hans dampf front and a nobby nic rear(both 2.35) to a Yelli Screamy. I'm running them at about 35psi and they're not losing any pressure overnight but judging by the man milk marks all over the sidewall they're burping a good 4 or 5 times each ride. I ride relatively hard and it's quite rooty in places where i ride so i suspect that's what is causing it but i just wondered whether anyone else had a similar issue with the nic and the velocity rims?
Ta
Expert Crasher
Put some tubes in.
Always Learning
Ta
Obviously a different rim, but I have no problems with the 2.35 Nics on Velocity Blunt rims tubeless (using Rhythm strip and Stans).
Are you using the P35 tubeless conversion kit from Velocity? (Not that it looks any different from Stans tape....) If you are burping, you should see a drop in your psi. Could it be the "man milk" marks are from sealant dripping out along the bead? Did you shake and bake and lay them flat on each side quite a few times before mounting them up on your bike? What sealant are you using?
I'm running P35's with a WTB wolverine front and Nano rear...both folding beads. I've had zero problems so far running them from 25-28psi. I'm using the gorrilla tape method with custom schrader valves. I did the shake and bake method until i could see no bubbles and kept them stored at 40psi the first week when not riding. Now they lose Zero PSI when sitting.
I think the shake and bake method is definitely the key to a proper sealing.
i throw a little glitter in my stans mix for tires that don't want to seat. also, i don't run 35psi. do you weigh 220 or more?
Discussion Starter #8
Re the pressure - no i'm about 200lbs these days but had read stories about these rims dinging easily so based it roughly on what i used to use with tubes and pulled it back a few psi as i ride through some rooty areas relatively aggressively. This is the first time i've used tubeless and my first 29er if that makes any difference to pressure. Will try dropping it down to late 20s and see if that makes a difference.
For the query re the tape....using the stans yellow rim tape on there.
I followed the stans video as i'm using their sealant. Will search shake and bake as i have no idea what that is!
Thanks for the opinions
Shake and Bake just means...hold wheel at 9 and 3 o'clock...let stans run to bottom...shake wheel back and forth while rotating wheel like a ticking clock...then set flat on one side and let sit for a few minutes...pick up and redo previous action and lay back down on opposite side.
Just keep doing the above and use soapy water to check for air leaks. When you get down to just a few tiny leaks, then you can just focus on those spots. Try to keep them pumped up everyday. Go for some rides as well...that will allow the sealant to hit key spots when the tire flexes slightly.
Hope that made sense, lol:thumbsup:
I'm with stupid
Different wheel but I had the same problem with my nic 2.25 and Ralph on Mavic wheels. I think the bead fit is pretty loose on the new tires after so many complained about them not being able to get them on the wheel. I ended up putting tubes back in the front of my nimble 9 because I was burping the tire at 37-40psi. Just didn't trust it to stay on.
I tapped that
This place needs an enema
P35's are great rims, but they are *sketchy* tubeless. Despite Velocity's claims (and their "tubeless" kit) these rims really don't do well for aggressive riders when run tubeless. No matter the tire, pressure, tape/valve combo, sealant mix, etc..., they *will* burp.
The only flaw in the mix is that Velocity continues to claim that they can be run tubeless. Great rims otherwise.
Discussion Starter #12
Ok, thanks guys. Trrubicon - they stay up fine so the seal is good when not being ridden, its just when i bash it over some roots it seems to burp. It sounds like Mikesee might have it but just checking i was doing anything stupid. Front seems to be fine tubeless so I'll just stick a tube in the back sometime, not the end of the world.
1 - 13 of 13 Posts
