I’m looking for feedback from someone with experience running the Velocity Blunt rim with a Schwalbe Racing Ralph 2.4 tire. Yesterday during a ride my front tire exploded off the rim. It was the first ride on my new rims; I’d previously had the RR 2.4 mounted to a Bontrager Race X Lite. After converting the blunts using the Stan’s strip I mounted the tires (it’s worth mentioning they’re the non-UST version) to the wheels with ease. I was running 29lbs of air and at the point of failure was rolling on a relatively flat section at a slow pace. I was able to remount the tire using an inner tube and it was fine for the remainder of the ride; I did notice the tire itself was stretched and seemed to barely fit the rim.
If anyone has successful experience with this set up please do share details as I’m quite fond of the tires and would like to continue riding them without fear of a catastrophic failure.
One other point worth noting while I was repairing the tire and my ridding buddies were recovering from getting the sh*t scared out of them from the gunshot sound the tire made they asked what pressure I was running. When I told them 29lbs they felt my rear tire which was a RR 2.2 and they all started saying “that’s way too much pressure, your pump gauge must be off, no wonder you’re tire blew off the rim…” I couldn’t argue with them because the tire felt as hard as a rock and after their comments I let some air out so the tire was softer. Upon arrival back at our cars we tested the accuracy of my pump with a digital gauge and it was spot on. We then started to speculate that larger casing tires like car tires might function on lower pressures, no one there was qualified to comment on the physics of this suggestion but it seemed to make sense. So, as a second part to my question has anyone else had similar thoughts about 29er high volume tires and air pressure?
Thoughts, comments, feedback please.
