Looks like the first production run will be w/o stud pockets, unfortunately, but I will put some pressure on them to have it incorporated on the later runs.
I'm confident that the weight is legit, even though it is pretty amazing. As mentioned, everything that I have weighed from them since last fall (tons of Mission, Vee-8s, Speedsters have been at least 10g lower than claimed weight, so I will not be surprised to see these below 1250, and even lower once we get the 300 stud pockets incorporated. Will likely be one studable and a regular version.
Pugsley on RD rim: I doubt it, as if I recall correctly, the BFL, which is ''only'' a true 4.5 on 100mm rim barely fits. Snowshoe is specified as a true 4.7 on a hundred.
It should fit those frames where Lou is just a little too big. Like our MK2 bikes. That is why I sepcified Snowhoe at a true 4.7 instead of 4.8 and limited knob height to 6mm vs 7mm on Lou. Slightly more space so that more people can run monsters bigger than 4.5.
It will also be interesting to see the performance of their new Silica compound. Silica is used in auto winter tires (of the Nordic type) in order to keep them soft when the temps drop.
