1 - 20 of 21 Posts
I'm planning the build of my orange Vaya (since it's 10deg. here today, it's the only cycling activity available to the sane), and I'm looking for some suggestions and/or validation regarding tire selection.
My LBS carries Continental and Schwalbe (and others that don't matter for purposes of this thread). I'm considering the Conti Top Contact 42 or Schwalbe Marathon Extreme 40, both of which are ETRTO 42-622. I'm also considering the Specialized Hemisphere or Crossroads, both of which are available in 42. I'd like to go fatter, but I'm not sure the frame will accept a 47 (which the Conti is available in) or 50 (the smallest 700c size for the Schwalbe Big Apple and the next step up from 42 for the Spec. Hemisphere)
http://www.conti-online.com/generator/www/de/en/continental/bicycle/themes/city/tour/topcontact/topcont_en.html
http://www.schwalbetires.com/bike_tires/road_tires/marathon_extreme
http://www.specialized.com/us/en/bc/SBCEqProductList.jsp?sid=2011EquipTiresCityUrbanMulti&pscid=1008&scid=1015
This bike will see about 60/40 pavement/gravel & dirt road. Is one of these tires a run-away best option? Are there other options I should be considering that are better?
As always, I appreciate everyone's input.
Discussion Starter · #4 ·
My frame will be a 57. Salsa's website says it will take a 42 tire with fenders, so I assume it will accept a somewhat larger tire without fenders. The jump to 47 is probably too much, though. As much as I would like to get everything decided before the frame arrives, I might just have to wait and try a larger tire out. I think the rear will be more of an issue than the front - the pics I've seen look like the fork is pretty roomy.
Discussion Starter · #6 ·
According to this: http://www.dtswiss.com/getdoc/e90f3ce4-ad4d-4bb1-b676-0ec4f2fb152d/TechnicalDatasheet.aspx
it is 1.5" or about 37mm. Seems kind of wide for a minimum, especially considering that their TK 540 rim is only .3mm narrower (23.6 vs. 23.9) and the minimum tire width is 1" or 25mm. I'm guessing that the intended use as a MTB rim is being factored in to the minimum tire width recommendation on the X 470, and you could probably safely go down to a 28 or 32 for road use. The inner bead width is probably about 18-19mm - Sheldon Brown's rim/tire width chart suggests a range of 28 to 44 on a 19mm inner rim width. http://www.sheldonbrown.com/tire_sizing.html#width
?hipster?
I'm using the stock DT x470 with Conti Tour Rides 42c w/fenders, no problem. There is almost a centimeter clearance on each side to the cs.
I've also used Conti Contac 32c @75 psi w/o a problem. There is a sticker on the x470 that reads 4 bar max, but as SAWS mentions I believe this refers to mtb use. There is an asterisk on the data sheet which refers to the tire max psi rating, which will be much higher than 4 bar.I would like to use a 28c for high speed road riding but that sticker gives me something to think about.
rth009
MoementumI've also used Conti Contac 32c @75 psi w/o a problem. There is a sticker on the x470 that reads 4 bar max said:
No problem down to a 700c x 32, eh? Thats great news as 32 plenty small for my uses. What do you mean by 4 bar max. Im not familiar with that terminology.
Discussion Starter · #13 ·
My Vaya is supposed to ship tomorrow, according to my LBS. Should see the frameset in about a week. The tire question should be pretty easy to answer at that point.
Enjoyin' life....
My frame is on the way. My Vaya will run with Marathon Supreme 700x40's which were used on my older version Fargo for a while. Admittedly road and path biased but I won't be singletracking with it anyway, the Vaya is for touring. The Marathon's work okay on gravel and have good puncture protection but if I was gravel grinding, I'd use something different. Probably the cross version.
I ordered a complete. I haven't talked to my LBS in about a week. Should probably do that today!
1 - 20 of 21 Posts
