I currently am running a 700x2.30 spring and weigh around 200 lbs. Is this right or should I be running something else?
It depends if you can get the correct amount of sag within the 2 turns of the spring adjuster ring. If not give Fox call. A replacement costs about $20.00 US.dingleberry said:I currently am running a 700x2.30 spring and weigh around 200 lbs. Is this right or should I be running something else?
