Do you have the Phantom build up yet?Not yet...but soon. DVO is earmarking a Jade X for my Phantom V3, when they become available.
nice dude what was your previous bike ? i currently ride a 2017 trek remedy and worried the prime will feel huge on the trailJust finished my Prime build last week and rode 12 miles yesterday. I was afraid that I wouldn't like the long chain stays or wheelbase but it's the best turning bike I have ever ridden. Suspension felt great and I didn't make any adjustments from what I had set in the garage. Just need to bleed the rear brake and get some more dirt on it.
XL 32.2 lbs w/o pedals
2016 Transition Smuggler, also XL. I was also worried since the Prime is 2 inches longer but right away it felt natural. No weird body English needed to go through some of the tight turns on the downhill like I needed on my old bike. Flatter flowy sections at the bottom of my local trail system were just as fun if not more.nice dude what was your previous bike ? i currently ride a 2017 trek remedy and worried the prime will feel huge on the trail
Ripley Carbon Frame in medium is 6lbs and a Phantom is 7.8lbs. So for the same build a Phantom is only 1.8lbs heavier than a V4 Ripley- not bad considering it's AL with a PB Shock. 1/3 of lb in the shock alone.The Vital review is exactly what I wanted to hear about the Phantom, but 31 pounds is just a little disappointing. Would it be reasonable to get a Phantom down 27ish pounds?
Also, any opinions on using a non reservoir shock on the Phantom? Something like the Fox DPS.
Remember that in the Vital review they used control tires that were very heavy. The Assegai 2.5WT EXO+ is 1,125 g and the Aggressor 2.3 DD is 1,115 g. That's 2,240 for the pair. You could easily lose weight there and still have a good solid set of tires. As Twotone said, the frame is 7.8lbs so with carefully selected parts it wouldn't be too hard to build a pretty light bike.The Vital review is exactly what I wanted to hear about the Phantom, but 31 pounds is just a little disappointing. Would it be reasonable to get a Phantom down 27ish pounds?
This ^^^^^^^^Most mid priced trailbikes these days are hovering around 30-31lbs, even carbon ones. The tech exists to make them lighter but then things start to be less durable.
My prime with carbon hoops, carbon bars, coil fork and exo tires weighs a smidge over 32lbs.
My carbon firebird with alloy hoops, carbon bars, carbon cranks, coil fork, X2 and tire inserts weighs....a smidge over 32lbs.
I think bike mfrs are sick of bikes breaking, so they keep around 30lbs and just make them more capable.
Put fast tires on your bike if you want it to feel fast.
