1 - 4 of 4 Posts
I'm assembling the dropouts on my Rune which has boost v2 dropouts.
With the bolt screwed in all the way to the hanger, it can slide back and forth. I assume not a problem once the wheel is in there.
Is this normal? Below is a pic, can see the extra space.
Bicycle accessory Line Metal Steel Machine
Not normal. The bolt should be flush with the dropout. Carefully check that you have not cross threaded the bolt. I think the factory loctite makes it seem like it is a bit tougher to thread in than expected. Just be very careful!
Discussion Starter · #3 ·
Yeah it felt like it was bottoming out, so I just stopped. I gave it the beans (gently) and now its fully seated. There was quite a bit of dried threadlocker gooped onto the threads...
1 - 4 of 4 Posts
