V-brakes are obsolete.
Don't toe the pads if it's not squeeking. Make the pads parallel to the braking surface. Don't position too high (near the tire) or too low (as it wears, you don't want part of it hanging off the rim). Make the caliper arms as far apart as possible by using more spacers with the pads. This gives it more leverage. Keep your rims clean, grit and stuff will wear the braking surface much more quickly.
Use high quality lines and housing. Use smooth bends and turns, try to keep the routing as short and direct as possible. Use a lube like Rock&Roll Cable Magic on the cables.
You don't want the lever biting real early, having it bite in a little later gives your hands more leverage, and towards the end of the pull is where the hand is the strongest.
There should be little screws or bolts on the side near the studs, these adjust the spring tension on the arms. Putting more tension on one arm (dialing it in clockwise) pushes the brake further away from the rim, and pulls the other arm in closer. You can also use these to adjust the feel of the brake at the lever. More tension for a snappier return and more resistance to pull.
