These are very different bikes but I'm intent on using them for the same purpose.
I ride pro DH on our circuit and I want to limit myself to intense in this choice for sponsorship and connection reasons. This bike is going to be a through and through DH bike but around here most of the DH courses are around 80% smooth, pedally with a few jumps. There are a few very rough courses though, and in a year there may only be just one or two rough course races.
Uzz pro'si:
Light DH build, single crown, angle set, expected to be in 34ish lb range without much strength compromise relative to frame strength. I would probably invest in a good shock in this option to compensate as much as possible for the lack of travel. The bike will probably be a lot more fun to use outside of racing on normal rides. I'm assuming it will also pedal a lot better, be a lot easier to bunny hop, and bring through tight corners. Acceleration is also a big plus for the courses that don't have very nice flow.
M9 pros:
Full on DH, probably 40lbs+, much more expensive as I would need to buy a new fork, cranks, etc. Less practical but the confidence of a DH bike is something that my testosterone as been hungry for. I am also worried that at my level of racing, that one rough section or that one big drop could win or lose a race. Not to mention stiffness and cornering advantages of the M9. I'm wondering if I could pedal this bike just as well as an Uzzi or if I could set it up to be nimble with the g3 drop outs. Big plus will also be me dying a little less inside after overshooting drops or stepdowns, which is pretty common here.
Looking for opinions about the Uzzi's stiffness/strength and the M9's pedal-friendliness and how nimble it is. The HA is a bit steep on the Uzzi but an angleset would fix that. I'm leaning toward the Uzzi right now but no self respecting downhill racer would not be craving a full on DH bike!
Uzz pro'si:
M9 pros:
