Not sure if there are any solid spoke bed 29er rims out there. I can definitely recommend the Bonty system though (Mustang or Duster). Uses regular spokes and nipples, and no tape involved.
What seals the spoke nipples?spsoon said:Not sure if there are any solid spoke bed 29er rims out there. I can definitely recommend the Bonty system though (Mustang or Duster). Uses regular spokes and nipples, and no tape involved.
Darn! No 29" Mavic.spsoon said:Unless I`m missing something on the Mavic site, the XM819 is a 26`` rim.
Have your LBS or favorite wheelbuilder relace your current hubs to some Stans or Bontrager TLR rims. In holding out for a Mavic tubeless rim you're:Lifespeed said:I don't want a rim that seals the spoke holes with tape. I would like solid aluminum holding the air in, like my Mavic 26" wheels do.
Is there anything out there? Are the Crossmax 29ers proprietary hub?
Tire recommends for UST or tubeless ready appreciated also.
So tell me how you really feel about Mavic. Like I said, I have had excellent results on my 26" bike. As to the nipple arrangement, I did not find it to be over-complicated to lace a set of rims.mikesee said:Sorry--I don't have a lot of respect for, nor faith in, the crap that mavic has been putting out the last few years.
You might just want to pick up a Stans rim strip for your existing rim and then get some Tubeless ready tires from any of the multiple manufacturers available and suited to your terrain.Lifespeed said:I've decided I had my last flat tire today. Got goat-headed big time, 20 thorns per tire. Pretty ridiculous.
I've been putting it off, cost and all that. I would like to find a true UST rim that I can lace on to my Lefty front hub. The rear hub is shimano FM-M475, the front is Cannondale. They are 32-hole. I'm not sure there is any reason to replace the hubs, other than getting a good deal on a pre-laced wheelset with a Lefty hub. Neither the good deal or the Lefty hub seem likely, however.
Thanks, I think a couple people have done that. I believe a set of the c29ssmax wheels are around $500, plus the cost to swap the front hub. Not particularly cheap, but a possibility.eliflap said:i saw a picture of a 29er front wheel "custom built"
SLR red lefty hub , as 26"model
crossmax 29er UST rim
mavic spokes
here in this forum
Then what difference does it make?Lifespeed said:I do intend to use sealant for punctures, but I prefer the rim seals without it.
Years ago mavic had it all figured out. Reasonable prices on quality products that they stood behind without question. These days? Not so much. Sub par product, grossly inflated prices, and a distinctly french inability to hear and act on what their dealers are telling them as far as upcoming product trends and current product failure modes.Lifespeed said:So tell me how you really feel about Mavic. Like I said, I have had excellent results on my 26" bike. As to the nipple arrangement, I did not find it to be over-complicated to lace a set of rims.
My experiences represent a sample size of one, so always good to hear another perspective. I don't understand why a Mavic rim is any more likely to blow a tire off. Is the UST bead interface not a true standard? Do different mfg's implement different bead hook dimensions?
Do Bontrager or Stan's rims require sealant to seal the spokes, in addition to the strips? Unless the strips are glued in, I would think sealant is a requirement. I do intend to use sealant for punctures, but I prefer the rim seals without it.
Thanks for the info. They can't make the rim diameter to spec? Wow!mikesee said:Years ago mavic had it all figured out. Reasonable prices on quality products that they stood behind without question. These days? Not so much. Sub par product, grossly inflated prices, and a distinctly french inability to hear and act on what their dealers are telling them as far as upcoming product trends and current product failure modes.
Been there, done that, not worth the $ anymore.
The mavic 29" UST rims are undersized. Simple as that.
Bontrager and Stans rims don't necessarily need sealant--I've run both of them without it. The tires will leak down after a day or two, but that's a function of porous tire casing. In short, yeah you'll need sealant to seal up the casings, but you'd need it for the goatheads regardless.
MC
Similar to the mavic with a solid spoke bed and a threaded insert. That is a lot of cash however just to get tubeless tires without a rim strip.Lifespeed said:What about the Shimano WH-MT75 tubeless 29er wheelset with a front hub from the WH-M975-lefty wheel?
The look to have a similar hub to the crossmax wheels. Of course, then you have to buy Shimano centerlock rotors . . .
Anybody know anything about these rims? They claim tubeless compatibility, whatever that means. How are the spokes sealed?
