Non UST tire on UST rims works great with a rimstrip.
One big problem I see over and over is that people make the assumption that with a non-UST tire, a UST rim is going to work better, and won't even need a sealing strip. Then they have trouble with the tire burping.:eekster:
A UST rim is designed to do ONE thing. Seal to a UST tire.
It was never designed to make an airtight seal to a standard tire!! :nono: If this was the case you would not even need UST tires. A standard tire was not designed to properly seal to ANY rim. It was designed for a tube. But it can be made to seal very well to any rim with a rimstrip such as Stan's, or a split 20" tube.
Now it is true, that some standard tires sometimes get an ok seal to a UST rim. But it is a big crap shoot, and you seriously risk a catastrophic burp that might put you on your face. I used many standard tires on Crossmax SL UST rims. First with a Stan's strip, and then with a simple 20" split tube. This ensures that the standard tire that was not meant to seal to the UST rim, does get the proper seal it needs. I never once had a tire burp using this method over several years of use.
You can do some searching and find many incidents of people suffering burps when using standard tires on UST rims with nothing else but sealant. If you want to dramatically increase your safety, use a sealing strip with that standard tire on ANY rim you set it up tubeless on.
Also, if you set up a standard tire on a UST rim using a Stan's or "ghetto" strip, do not inflate over 40psi. You are not seating a UST tire. Follow the same inflation guidelines as Stan's advises for standard tires ran tubeless with his rimstrips.
