SID Pumping Issue
ricer said:
I am trying to put air in my new SID. I pump the chamber up to the appropriate psi, and start to unscrew the pump head from the valve and all of the air escapes...what am I doing wrong?
Does all the air escape? or is it a brief PSSSSST (that sound when the air escapes), then it stops.
If all the air escapes, the schraeder valve on the fork may be sticking or faulty.
If it is a long PSSSSST then I would have to think maybe the pump itself.
If it is a short Psssssst, that my be the pressure escaping from the pump - when you pump your fork to Xpressure, that same pressure remains in the pump until it can escape when it is removed from the valve - hense the Pssssst noise.
An additional note. If you check pressure with your pump. after putting the pump back on the valve, give it one full pump - that will give an accurate reading of the pressure before you released some air back into the pump.
