I would be interested to know whether there is an issue as well since I am contemplating between an Avid Mechs and a Hydro....
fishy
fishy
Hey Tscheezy, the brake will take an endcap, just not the standard one but one with a more narrowed nose. I use the Jagwire POP (points of power - or something goofy like that) ferrules and they seat fine inside the brake stop. However, I have some slightly wider non-POP Jagwire ferrules and they are too wide to fit.tscheezy said:Also, the Avid mechs don't take a housing end cap (ferrule) where the cable housing enters the brake. The naked housing is supposed to slide right down into the brake's stop. This is hard to see because it's down inside that rubber boot. If you use a housing end cap, the housing just sits perched at the entrance to the stop and can bind if the housing moves (not usually a prob with horst-link bikes where the brake sits on the seat stay, but could be an issue with non-horst 4-bars).
since it may be a while until Tscheezy gets home and has his Nixon installed w/ full ride report i am sure ...feel free to stop on into the shop anytime Gonzo ...i just had a call from Manitou that my shipment of forks left and should be here by friday. And if you come down on saturday you could join a few of us on a ride.gonzostrike said:Tscheezy, you called it!
I'd used a ferrule that is too large in diameter, and the cable wasn't seating properly in the caliper. I didn't notice it because it was behind the little rubber boot.
sux to be idiot me.
thanks, Tscheezy!
hey, how's the Nixon?
Hey Chad, how's your summer going?nwmtb said:since it may be a while until Tscheezy gets home and has his Nixon installed w/ full ride report i am sure ...feel free to stop on into the shop anytime Gonzo ...i just had a call from Manitou that my shipment of forks left and should be here by friday. And if you come down on saturday you could join a few of us on a ride.
later, Chad
http://redbarnbicycles.com/
