1 - 15 of 15 Posts
Hi, I have a bike that has a 6-speed freewheel type cog, but I want to use a new wheel that takes cassettes.
Since you can't get 6-speed cassettes (only freewheel), can I use a 7-speed cassette? I am aware the spacing is different, so what will that entail?
Can I change my shifter to better suit to a 7-speed?
I am looking at the Shimano HG20 7-speed cassette, which is available in two different ratios: 12-28T, or 12-32T.
What ratio is better for my purposes?
Thank you for your input!
Discussion Starter · #4 ·
I don't care about being able to use all 7 speeds, 6 would do if if can get away without changing shifters... (at least for now)
There is a 'reach adjust' screw on my shifter, and a full click goes through 2 gears at a time. Can I adjust that screw so my gears are aligned properly? (i.e. no wanting to jump to next gear etc)
Thanks.
edit: not sure about the dropouts, but the new wheel (without the cassette fitted) fits the frame, I tried it out... is that what you are meaning?
The bike had a 6-speed freewheel type cogs on it, but I have a cassette-type wheel I want to use... since you can't get 6-speed cassettes, I need to go up to 7-speed.
Discussion Starter · #8 ·
I have one chain whip and a locking nut I use to take the non-freewheel type cassette off...
What is a cassette tool?
Is there any Youtube tutorials or anything? I can't find any. I thought the cogs were one solid piece... how are you able to space them out? :madman:
The cassette tool is like a socket that the lockring so you can tighten it down.
I have seen respacing instructions for 9/10 speed cassettes and you'll be doing basically the same thing. Check Sheldon Browns site for it.
If your cassette doesn't have loose cogs you won't be able to respace it.
Discussion Starter · #10 ·
I used an adjustable spanner last time with the locking nut and chain whip to remove the cassette.
I have seen a cassette before where the two end cogs come loose, if the 7-speed cassette I ordered is like that, will I be able to change the spacing?
And where do I get the spacers? What are they called exactly?
Cheers.
Most shifters of that era had a switch that changed them from indexed to friction shifting. The way that I remember it is that 6 speed and 7 speed freewheels had the same overall width, the 7 speed had tighter spacing to fit in the extra gear. If your shifter has switch to change it to friction I would just do that.
1 - 15 of 15 Posts
