1 - 5 of 5 Posts
Hello,
I am looking at getting a new seatpost. I have decided to go with a carbon post and have narrowed it down from countless seatposts, to the USE Alien carbon.
The main question i have is -
I need 19.5cm (195mm) of exposed post - measured from bottom of seat rails to top of seat tube. So can i use a USE Alien that has a length of 270mm from bottom of post until where the seat rails ae in the clamp ? which means 75mm will be in the seat tube.
Also what is the minimum insertian level for these posts ?
And can i use a 27.2 diameter post in a 27.2 seat tube without a shim (ie am i suppose to use a 25.0 post with a shim for 27.2 dia)
Thanks,
Adam
avg. joe
Not quite your answer...
I can't answer your questions, but I will give a plug for the post and it's company. I have had my post for 2+ years and had no problems. I did call their 800 number once and they were quite friendly and answered the questions that I had for them.
Give 'em a call and get the info straight from them.
Tom
Banned
here you go...
caballero said:
Hello,
Thanks,
Adam
i sell these posts and just checked the measures:
the minimum insertion is 60mm which leaves ca. 205-210mm of exposed seatpost, enough for your needs.
the newest generation of these posts doesn't need a shim anymore. they got reinforced compared to earlier versions. just make sure your seattube is smooth. weight of the new ones is 149g for the 27,2/270mm size.
1 - 5 of 5 Posts
