1 - 20 of 25 Posts
Just Ride!
Just wondering if anyone has any feedback experience with any of the USB commuter lights that are starting to show up? I am strictly a daylight commuter, so I am just looking for the flashing LED effect to better be seen. As well, I like the idea of not having to buy batteries. I am down to the Blackburn or Topeak combo sets.
I don't know of any bike tail light shoot outs, does anyone? So comparing them in usefulness and to the best out there is difficult, Some points you may wish to ponder (we need to keep healthy (not hit) all the cycling commuters we can get!):
First point. You are buying rechargeable batteries in the lights. So buying separate rechargeable NiMH AAA cells is not different in the sense of having or not having rechargeable batteries. Agree that not buying disposable ones all the time is a good idea.
Goal is to be seen and not hit. Getting through to drivers who are on the phone and not paying attention is tough. Worse some locales than others. Here, well aimed Planet Bike Superflashes with recently charged NiMH cells don't do squat in the day at a distance. Essentially they are good short range so I use them as side markers or on the helmet for closer drivers only.
Daytime requires more punch than most blinkies have. You need to be seen, registered, and evaded in time by drivers. Unless the lights claim daytime use, they won't be. If they do, they MIGHT be OK. Check out the Radbot 1000 in the 'Another Commuting Thread About Lights' thread both daytime and night videos on the second last page show this light in action. Want more power? The Dinotte 140 has it at a price, or go DIY.
I am betting my physical well-being, so the need to pull the cells and swap in charged ones every 8 hours (100 mAh cells) or so in summer and 4-5 in winter is a small price to pay IMHO. As they say 'Safety does not cost, it pays.' Also, if on a longer ride, I can carry spare cells or buy cells en route if need be.
That's my take. It's a different form of Highway Robbery: It's your money AND your life.:D
I don't like buying batteries either, but rechargeable batteries and a charger work fine also. In fact, NiMH batteries are better for lighting because they can output more current longer compared to alkaline batteries. For LEDs which depend on current, NiMH will run the lamp brighter and longer than alkaline batteries.
From Amazon, $10 buys a set of four Sanyo Eneloop AA or AAA. A smart charger can be bought for about $20-25, maybe less.
I got 4 Maxell, Ooops! Energizer 1000 AHr AAA's for under $8 with tax using a coupon and catching them on sale at Target. My old 700 aHr Radio Chack ones were still going strong but the added run time is great.
Looked up the Rav-X. 45 lumens max is nice, but with no lens to concentrate any or all the 5 LED's, they emit into almost 180 degrees. That will spread teh 45 lumens so it will not punch hard enough for a sunny day. Runtime on full is 1 hour, flash is 5 hours so about a Radbot's winter runtime. If I didn't have the Superflashes already, I'd consider them as side marker lights. Or as backup lights or the white ones as be seen lights with a narrow beam headlight, BUT not as a main marking light. The video I was was against a door in a house. Completely useless. It shows they light up. I want to see them on a bike at distances. Anything else is a waste of video processing and posting and makes me think they are poor.
Just Ride!
Discussion Starter · #7 ·
rollinlegend said:
You should look at the new Rav-X light sets that are charged by usb. They are pretty bright and small, they can fit on almost any section of the bike. worth a look.
Wow, that is a pretty obscure company and they really do not seem to have a distribution network!
LEDs generally have a much narrower view angle than 180. 90-120 degrees is typical; sometimes even less depending on design.
Dinotte 300R
Spurred by another thread regarding batteries & Dinotte lights I saw this on their site:
http://store.dinottelighting.com/sh...2=741202950&ProductID=111&Target=products.asp
Pricey - but is there anything else out there with similar qualities? I have really gotten to like the convenience of USB charging. It seemed gimmicky at first - but now when I get into the office plugging in is part of my routine.
Just Ride!
Discussion Starter · #12 ·
I am enjoying looking at all of the recommendations that people are making, but would enjoy hearing some pros and cons on the systems with actual feedback. Many of them seem like very expensive options, which I could justify if I needed them to see at night. I already have a 900 lumens headlight, but just need strobing led's that can be charged at my desk when low and to get noticed in the day.
These lights are perfect for what you describe, the only thing that I am not sure of i how long they will last. I have only had them since fall and haven't used them more than 4 or 5 times with winter leaving me bikeless.
To the OP: Forgive this digression. It is too important to let lie.
Short reply:
Output angles of bare LEDs even at 90 degrees are too wide for a good effective 45 lumen light IMHO. If a designer has a few tens or hundreds of lumens in a bike tail light he/she needs lenses or reflectors for it to be effective at distance and in the daytime. Using bare LEDs is a waste, and little better than no tail light, at all with current distracted drivers. That's my take.
Long reply to save some back and forth: :)
Firstly, the 90 and 120 degree angles are NOT a cutoff for all output of an LED. It is the point where the intensity is 50% of the peak intensity on axis. To get the power output of the center and the rings around it like from 120 to 180 degrees, you have to integrate in a circle over the parts of the beam you are interested in. I made that area dependent error too, so I sympathize.
So the LED output curve by angle defines the axial peakiness of Power LEDs in a cross section of the beam. It predicts how well a small lens or reflector can tame a goodly part of the output into a narrow, say < 10 degree Full Width Half Maximum (FWHM) beam which is the total angle where the beam is at or above 50% of the max intensity.. You may still get an appreciable output from angles wider than the 50% point depending on the shape of the curve of teh lens or LED. It has little to do with my comment about the Rav-X.
Secondly, the hard case 1/4 watt LEDs are not equiped with a gel lens systems of power LEDs used to maximize light output per watt. So one would expect them to have an even broader output, possibly a ragged one, but I have not seen any plots. That was not my point either.
My point is that with only 45 lumens, a lens or reflector is needed to concentrate the light into a beam if you expect it to be seen at a distance and in the day. This is REGARDLESS of its peakiness or lack thereof in output. the Rav-X is using the primary lens package of the LED only, so it fails to control its decent but small output well enough.
In case some are not convinced, let's take the 90 degree example and see what sort of tail light beam that get's us: A 90 degree beam is 45 degrees to either side of the bikes' center line in a cone if placed properly. So it is lighting things up fifty feet to each side fifty feet behind the bike (and above it) and a triangle on the road at the 50% of max level. there is still a lot of output even wider than 45 degrees to each side. Such a light sprinkles the photons in a broad swath. A lens or reflector is like placing your thumb on a water hose for a long distance brother-soaking jet, versus trying to get him at the same distance with a sprinkler covering 90 degrees with the same hose and pressure. Pathetic. (Unless you attach a Fire Department Pumper for more volume and pressure (just like more lumens), but the Rav-X has only 45.
The Planet Bike Superflash, a long time 'best of the blinkys' choice for proven reasons, puts out a narrow beam that is as wide as the lane at something like 100-200 feet behind you, and is just visible in the day under the worst conditions at 1/4 mile. It is only about 1/3 the lumens of the Rav-X with a fresh set of batteries and 1/4 of that after the first hour (really drops after 10 hours on steady mode). However, it concentrates its light instead of scattering it. There is still a good amount of 'spill' which is light outside the main part of the beam to help with people who are closer, plus they let otherwise wasted light out the sides to help that, too. Although it can be seen, it doesn't attract cell-phone using driver's attention soon enough or strongly enough in the day, unless they are very bicycle conscious. (Not here.) The Radbot 1000 is much the same but with about 25 lumens output for 8 hours (2X the Superflash), enough to be easily seen in the day at 1/4 mile in 'washing out' low sun conditions and is clearly visible by even slightly inattentive drivers because of the lens. There is no excuse for not seeing it. I use a pair on the fast bike, the one that fakes them out.
So tail lights are NOT about firepower alone but accuracy. No lens or reflector: no accuracy, no distance, and no daytime punch UNLESS many hundreds or even thousands of lumens are thrown around.
The Dinotte (140 Lumens) mentioned above and twin Radbot 1000s (50 lumens) easily light up road signs behind so they help as a front warning device, as well as being visible for over 1/4 mile in the day. They have a bit wider beams, too. The Dinotte (140 lumen in a narrow beam) and my two 100 lumen DIY lights are easily seen at 1/4 mile with the sun washing them out, and maybe a mile under better conditions (according to friends who have seen me). At that distance the beams are very wide, more than 4 lanes but I did not check exactly how wide. Nice if you ride a shoulder along a winding road with traffic doing 50-70 mph. If they have a sight line they WILL see the lights.
Just remember you ARE betting your life. You can see my efforts to safeguard mine recorded with some effort and shared to help all here in the 'Another Commutting Thread About Lights' as well as Leopold Porkstacker's 600-1000 lumens DIY monsters that spread light. (Remember the Fire Pumper anaology for spraying a brother at distance with a sprinkler?)
Hope this helps.
I received a Cygolite ExpiliOn 250 a while back ago from a friend and it is very convenient to use on my road bike. I took it apart and replaced the original led with a XPG R5; much brighter now.
For a commuter/roadie, this is more than enough. I use a DIY bar/helmet setup for my mtb (~2500 lumen).
rodar y rodar said:
Dumb question time here-
by "USB light", are you guys talking about computer accessory connections? If so, it doesn`t mean that the lights are computerized or programable, does it?
No programmability. Just a port on the light that allows you to plug a mini-usb to usb via PC. Great addition since you can basically charge your light anywhere.
1 - 20 of 25 Posts
