1 - 12 of 12 Posts
ok I bought some stuff on ebay including disc wheels for my '99 m300. the rear rotor is hitting the seat stay barely. Could i shim it? It only needs like a 1/16" maybe 1/8" to clear it. would that work? am I the only one who has ran into this problem? any thoughts would be helpful:madman:
the rotor is hitting the seat stay? that doesn't sound like any easy thing to do... is the caliper installed as well? Better still do you have a picture I can't see it in my head....
~Disc~Golf~
hmm, shimming the rotor would move it closer to your seat stay.
i don't know how close you are and at what point the rotor contacts the frame, but here's a couple ideas-- maybe try a different rotor style... you may get some more edge clearance say if you went from a 'roundagon' to a round...
a cheaper method if ya got some cone wrenches [or similar] is to put in a couple 1mm thick washers between the jam-nuts on the non drive side. this will shift the whole hub [rotor incl.] over 2 mm...but it may be a little harder installing/removing the wheel from the drop-outs.
pictures???
Discussion Starter · #12 ·
Sghost said:
How did you put disc brakes on a M300?
i found an adapter on ebay that bolts on to the frame and has the caliper mounts
i hadn't really planned on doing this i just got a good deal on the parts on ebay.
here are some pics or not they failed to download sorry. the rotor is 151mm coda 4-bolt. i think i'm just gonna shim it with a washer see how well that works cause it's only like a 1/16th off. on a side note which front der. is better the stx or the lx deore?
thanks for your thoughts everybody
1 - 12 of 12 Posts
