Thomson or Easton would be my preference. EA90 stuff is really good. Or is it EA30? Is it lower is better or higher is better? Im pretty sure higher is better...-=Canuck=- said:
Thomson or Easton would be my preference. EA90 stuff is really good. Or is it EA30? Is it lower is better or higher is better? Im pretty sure higher is better...-=Canuck=- said:For a race setup what are desirable brands and specs for a new bar, stem and headset?
Duckman said:WCS vs F99 beta.
All that flex talk is from the looks of the stem. I too was skeptical. The stem uses a 2 strap type(2pc) face clamp, that upon first inspect..looks rather spindly. The trick is, that the 200 degree bar mount means that 200 degrees of the bar is carried/supported in the stem body itself. The other 160 degrees is carried in the face plate. Most stems are 50/50, and I think the WCS series are the other way around, now that I think about it(having more bar overlap at the plate). The Syntace design takes the load off the face plate, and in turn puts more so into the stem body itself since it "captures" the bar for the most part=less faceplate material and smaller bolts without sacrificing stiffness. I have a 110mm WCS in service atm since 02. Also a Ritchey Pro, Pazazz(140gm generic from PP), RF Deus(1st gen and the stiffest stem I've used to date) and of course the F99. I swear the WCS feels more flexy then the F99, with the F99 feeling more like the stiffer(but heavier) Ritchey Pro. And I like the WCS, so thats good enough for me.
Just an unbiased impression of the stems mentioned since I've raced both.
Duck
