Hello,
I have a 1999 Stumpjumper FSR XC Pro that I would like to upgrade some parts due to wear and tear. I have purchased the MRP (Mountain Speed) X-Rated linkage from my LBS. I will be ordering the FSR Drop-Out bearing kit from MRP for it. I am looking for some suggestions for the replacement of the rear shock, the front fork and the crank. For the rear shock, I have to a Fox Vanilla Float R that came with the bike. I am not sure what the size is, I will need one that will work with the MRP x-rated linkage. For the front fork, I have a RockShox SID XC, and I believe it is 80mm. With the upgrade of my rear linkage, the rear travel will change from 75mm to 90mm according to MRP. Will it be wise to upgrade to a fork with a 100mm of travel? Or should I keep it at 80mm? Finally my cranks, I have the standard Specialize cranks, and I am looking to get them replaced. I am not sure what the size is. Will a 175mm crank fit with the E-Type front derailleur? Any suggestion will be greatly appreciated. Thank you for your time.
