1 - 9 of 9 Posts
· Registered
So I just did the upgrade on my 2016 yari and am a bit confused as to how much oil to put in the damper side now.
The bolts on the bottom do not have any markings, but then again, I upgraded the damper. So how much should I be adding, 10 or 5? A stock yari comes with 10 on both sides. All newer rock shox forks use 10 on the charger side and 5 on the damper side. So I am a bit conflicted. Please help!
· Registered
But the newer forks with the debonaire spring only use 5 on the spring side. Thats why i ask
They all use 10ml. Don't know where you get 5 from.
10 lower, 3 on top of the spring. The 3 on top eventual lubricates the spring piston and lower seal head from within the negative chamber.
· Registered
Only their 32mm forks take 5ml or 6ml, depending on the fork That's down from 8ml prior to about 2012. That's in each leg.
All RS 35mm forks are 10ml in each leg.
The ZEB takes 20ml.
Download the Rockshox Front Suspension Specification document, 2021 for their latest thinking.
  • Like
Reactions: IMeasure
1 - 9 of 9 Posts
