I have a Giant Yukon who is in need of a new chain, bottom bracket, and crank set. Should I go ahead a upgrade the rest of the bike to 9spd? If I do choose this route how much could I expect to spend? Thanks in advance.
You'll need a new 9sp cassette and 9sp shifters as a minimum.jawilson20 said:I have a Giant Yukon who is in need of a new chain, bottom bracket, and crank set. Should I go ahead a upgrade the rest of the bike to 9spd? If I do choose this route how much could I expect to spend? Thanks in advance.
True. This advice is better than just answering your question. If you can salvage your crank and don't really need new shifters, why upgrade? Lots of money for 1 extra sprocket.jl said:Save some money and buy an 8-speed cassette, new bb, and chain you should be able to buy some chainrings instead of a new crankset. This is cheaper than all that I mentioned, plus new shifters and new derailluers.
Well the crank arm is what is broken... And I dont see a lot of 8 speed cranks for sale out there.tlg said:True. This advice is better than just answering your question. If you can salvage your crank and don't really need new shifters, why upgrade? Lots of money for 1 extra sprocket.
I agree with Warp, but I think that some derailleurs are only 8 speeds, some 8/9, and some only 9 spds, check on shimano.com or sram.comWarp2003 said:I might be wrong but cranks are 8/9 sp compatible. So are derraileurs.
What is not compatible are chains, cassettes and shifters (different spacing on cassette is what restrics this).
BTW... Is true that 9 sp is better than 8, but 8 speed setups are more resistant than 9 sp ones. Some people still prefer 8 sp over 9.
Your call.
As everyone's pretty much said, just buy a new crank 9 speed cranks work with 8 speed drive trains. As to whether or not 8 to 9 is an upgrade, is personal preference. All of my bikes that came with 9 speed drive train, I upgraded to 8 speed XTR/Sram setups. Just preference.jawilson20 said:I have a Giant Yukon who is in need of a new chain, bottom bracket, and crank set. Should I go ahead a upgrade the rest of the bike to 9spd? If I do choose this route how much could I expect to spend? Thanks in advance.
Mechs are dumb animals. As long as the cable pull is right (Shimano 2:1 or SRAM 1:1) they pretty much work for any number of speeds.rzozaya1969 said:I agree with Warp, but I think that some derailleurs are only 8 speeds, some 8/9, and some only 9 spds, check on shimano.com or sram.com
Cranks are. Some might argue that chainrings aren't. I run a 9sp crank with 8sp drivetrain and it works great. And very many others do the same. Rear derailleurs are compatible. Front ones can be an issue if the cage is narrower for 9sp chains. You could get more chain rub with an 8sp chain. But with Sram shifters you can tune that outWarp2003 said:I might be wrong but cranks are 8/9 sp compatible. So are derraileurs.
Depends on what you consider "better". They do have one extra sprocket. Guess that is better.BTW... Is true that 9 sp is better than 8, but 8 speed setups are more resistant than 9 sp ones. Some people still prefer 8 sp over 9.
I consider them better as the additional gear allows me slightly smaller transitions between gears. I'm a lightweight at 150 pounds fully geared and never have had strong legs (I'm not a gear masher, I'd rather spin faster). I've never snapped a chain without warning (You can feel a vague feeling during the drive side pedal downstroke at the pedal when the chain is about to snap - time to stop and use your chain tool).tlg said:Depends on what you consider "better". They do have one extra sprocket. Guess that is better.
