1 - 3 of 3 Posts
Hi guys. Found out that there is a chance my Mavic Crossride hub might accept an 11 speed casette according to this picture.
Font Material property Screenshot Number Parallel
Curently running a 9-speed Sram PG970 and I remember when I took it out some time ago, saw a spacer in there as well. (My complete current specs are below)
Font Number
So:
1) What do I need to check to be sure? Measure the hub?
2) If it accepts, can I mix and match from Shimano's M7000/8000/9000 series like the chain, RD, front chainring, shifter and the casette? Looking at that SLX/XT 46T one in particular.
Thank you.
Discussion Starter · #2 ·
It works! That chart is accurate, if anybody has a similar setup.
I had a spacer (1mm) with my old PG 970 11-34T cassette.
I got a SRAM PG 1130 11-42T and it fits perfectly on the Mavic Crossride hub model 2011, without any spacers.
Found a cheap M8000 XT RD, got the XTR M9000 shifter since it has 4 sets of bearings and I feel like I am loading a sniper rifle everytime I shift 馃槅
Just waiting on the narrow wide chainring and the chain I got is the SRAM 1130.
Bicycle Tire Bicycles--Equipment and supplies Wheel Bicycle wheel
Bicycle tire Automotive tire Wheel Bicycle part Wood
Bicycle Wheel Bicycles--Equipment and supplies Bicycle wheel rim Bicycle wheel
Bicycle Tire Wheel Crankset Bicycle tire
FYI all 9 speed mountain hubs will fit an 11 speed (or even 12 speed) mountain cassette. They will not fit an 11 Speed ROAD cassette.
1 - 3 of 3 Posts
