Hey guys,
I thought I'd pass along some new (and usefull to some) information pertaining to the owner's manual. Intense is currently in the process of updating their owners manual to include a bit more information for the Spider and 5.5. Here's a copy of the text revision that is being printed as I type this:
The Spider XVP is a cross country race specific design. It is not meant as a freeride or hucking bike. Warranty will be voided if used as a freeride style bike. Maximum recommended rider weight is 220 lbs.
The 5.5 EVP is an "all mountain trail" design. It is intended for aggressive trail riding. It is not intended as a freeride or hucking bike. Maximum recommended rider weight is 220 lbs
Spider RECOMMENDED FORK:
Optimum fork length is 80mm travel. All specifications represented in the catalog are based on an 80mm setup. Maximum fork length is 100mm. Use of forks longer than 100mm is not recommended and will void the warranty
5.5 EVP RECOMMENDED FORK:
Optimum fork length is 130mm travel. All specifications represented in the catalog are based on an 130mm setup. Minimum fork length is 100mm. Use of forks longer than 130mm is not recommended and will void the warranty
SHOCK SET UP:
Please see the shock manual supplied with your frame.
Recommended sag: A good starting point would be to set air pressure at your body weight minus 20 Lbs. This should set the sag at about 30% of the total stroke of the shock. This should give you the correct 3/8? ? ?? of sag at the shock shaft.
Caution: You will damage your bike and your shock if you under spring your shock or run your air pressure too low. If you bottom out the shock on a consistent basis you are under sprung and will damage the shock and the frame. INTENSE is NOT RESPONSIBLE for damage to the shock.
ADJUSTMENTS:
1. REAR TRAVEL:
The Spider XVP has 4" of rear travel and is not adjustable.
The 5.5 EVP has 5.5" of rear travel and is not adjustable.
Note: Be aware that extreme low seat-height can cause some tire-to-seat contact.
2. WHEELBASE:
The Spider XVP and 5.5 EVP does not have adjustable wheelbase.
SHOCK SET UP:
ADJUSTMENTS:
1. REAR TRAVEL:
2. WHEELBASE:
