-Everything is properly adjusted, and shifts accordingly
The problem is that when shifting, the when the chain hits the next ring it sounds really rough. Sort of like if you hit a pan with a spoon, instead of placing the spoon gently on it. It's not the same smooth sounding shift that I'm used to. Nothing has changed in the drivetrain other than I cleaned it, but I lubed it normally again.
help?
help?
