I've got a 2016 Fox 36 27.5" that I converted to coil (hacked together from old Van 36 parts), and two years ago changed the lowers to 29". Since then, the fork has not been working well. I have enormous amounts of shear force induced stactic friction, as much as 35lbs when pushing straight down on the handlebar with all the internals and seals removed from the fork. I've sent it back to Fox have the bushings resized several times, and each time it came back working well for one ride, then next ride awful and sticky again. The last time I sent it in, the bushings were replaced and then resized. Still only good for one ride.
I took the fork completely apart (again) and tried the lowers on with no seals. They go on with a bit of friction on the upper bushings, and then considerable resistance when the lower bushings engage. When I push the legs all the way on, it takes excess of 10lbs to pull them straight off (no shear forces). The old 27.5" legs come off with just a couple pounds of force, and a pair of Van 36 legs slide off by themselves.
If I only put one leg on at a time, they slide on considerable easier. I have left the axle off, to make sure the lowers are free to move. It seems the bushings are not only too tight, but also slightly misaligned.
Now, how does the bushing resizing happen? I recall having read about simply forcing a slightly larger tapered tube through the bushing to pry it more open. This seems like an amateur's approach to me, and not something that would give a permanent result. Or are they reamed prior to or after installation?
Can I expect Fox to be able to fix this? Maybe send in just the upper and lower legs, as well as the old Van 36 legs for reference of how good I expect it to be?
The last two years have been a frustrating experience, I have adapted to a fork that only partially responds to the terrain. Super smooth brake dive (very low shear forces then), chattery and rough on everything else. But I recently bought a new 2020 36, and put a Push ASC3 coil kit in it, and it is a marvel of a fork. Several rides in, and still buttery smooth. I am re-learning the joys of fast technical riding.
