1 - 12 of 12 Posts
crashes in parkinglot
So i've got some UST Hutchison on a mavic 823 rim, that i can't unmount (to put on a different tire). The bead (wire i think) is firmly in the groove of the rim such that i have been unsucessful just using my hands to un-seat it. Yes, i'm a 110# weakling. Any way, are there any trick that would help me get this dam tire off?!
I wanna talk to Samson!
The only advice I can offer you really is man up, that and some tire levers. My tubeless setup can be hard to take apart when I've had the tires on for a long time.
Discussion Starter · #5 ·
Yes stans
TNC said:
Did you have Stan's sealant in the tire?
Using stans. I've tried pooring some rubbing alcohol between the rim at tire, though there is no room for it to seap (sp?) in
the bead is in so tight that i can't get any tool in there to pry it out.
noMAD man
Not uncommon.
Yeah, the Stan's usually makes an impressive bead and rim lock. I use the Mavic sharp plastic tire tool to separate mine. Anyone's thin bladded sharp "plastic" tire tool will usually do a similar job. If that doesn't work, find a decently sized vise with some soft jaws...or at least pieces of wood...to clamp the tire as close to the rim as possible. Close the vise until one of the beads comes loose. Once you have one little spot of the bead away, you can use the tire tool to walk the rest of the bead around.
Glad to Be Alive
weakling.....just manhandled it and stop being a bunch of puussies
Put the wheel on the ground (on a piece of scrap carpet or something) and stand on the tire sidewall, each foot on the tire on opposite sides of the wheel. Using the inside heel edge of your shoe, push down on the tire right next to the rim. Works great, no pain, no damage to wheel or tires, been doing it for years. Once you break the seal, you can work around the rim (I just walk around mashing the sidewall down, but you can use a tire lever if you want to make it more difficult). Flip the wheel over and do the other bead the same way.
Don't worry about damaging the rims, they are plenty strong. Good wheelbuilders do this standing on the rims to pre-stretch the spokes when building a wheel.
Discussion Starter · #10 ·
TNC you rock thanks.
Vise and some wood did the trick. Thank you. I get to go DHing tomorrow!
Discussion Starter · #11 ·
I've built a couple of wheels and i've never heard that before, i ususally just use a screw driver to push the spokes around to stress relieve them.
1 - 12 of 12 Posts
