That would be partly because you did not shorten the chain and mostly because the XO derailleur is designed to track the angle of cassettes with larger cogs. Other than cage length the latter is the major difference between road and mt rear derailleurs.kdiddy said:My Ultegra 12-27 didn't shift as quick as my XT 11-34 on my SRAM XO equiped bike. I partly blame the fact that the idler pulley doesn't track as close to the cassette, especially in the larger cogs. I also didn't shorten the chain for the smaller cassette.
Hey Shiggy,shiggy said:That would be partly because you did not shorten the chain and mostly because the XO derailleur is designed to track the angle of cassettes with larger cogs. Other than cage length the latter is the major difference between road and mt rear derailleurs.
Road derailleurs are designed to track the shallower angle of a cassette with smaller cogs...Shayne said:Hey Shiggy,
How do road and mtb derailleurs differ in design? I've just measuerd up a few (STX long cage, 105 mid cage, Ultegra short cage, XT short cage, Record short cage) and aside from the obvious cage length difference they all measured out within 1mm of each other.
I admit I had no idea what to measure but I compared, center of mounting bolt to center of left side of parallelogram. parallelogram length c-c on pivots, width between parallelogram plates, and mounting bolt to cage pivot as would be in a plan drawing.
shiggy said:... (mt) derailleur(s are) designed to track the angle of cassettes with larger cogs...
