So...I hate the Twist lock on my Top Fuel. I would much rather have a push button style. I know I would have to do something with the dropper as well. Do they make a verticle style push button that will lock both shocks?
What do I do about the dropper lever? I can't run two underbar style levers on one side.The newer Fox underbar lever will work and is much better than their previous attempt. There's also a RS underbar lever that's almost identical to the Fox other than a heavier aluminum cover. I too prefer the underbar to the twist lock.
Gotta change the dropper lever to an on bar style, like the fox and spec levers, they aren't for everyone... this is why we specd the twist lock. I would personally recommend the Fox Transfer lever.What do I do about the dropper lever? I can't run two underbar style levers on one side.
I like that set up! Looks like what I am looking for. Where are you stationed?Here is how mine was set-up after having two TwistLoc's fail. The vertical/top one is from Fox for the dropper and the horizontal/bottom is the Fox remote for locking out the suspension.
It was pretty easy and allowed me to move the lockout remote more out of the way since it isn't used as much as the dropper remote. I actually left active duty in 2006 after 12 years but still work for the DoD back home in Birmingham, AL.I like that set up! Looks like what I am looking for. Where are you stationed?
The Fox fork on the 2020 Top Fuel is two-position. "Locked" or not, so a 3-position remote is not necessary.Went to regular seat post and looking for replacement for SRAM twist shift on my new 2020 Topfuel. Can I use scott twinloc and convert to 3 position lock out for front and back? If so, would there be anything needed besides the twinloc or any maintenance? I thinking nothing else would be needed as long as it is push to lock than I should be good.
It's a different damper.I understand that but if you look on fox website at that particular fork shows both a 2 position remote or 3 position manual so I'm wondering if they have different internals or if it's the same internals and you could do either 2 or 3 position with a remote.
Pic?Trek has released an under bar dual suspension lock out + dropper post remote. It has two levers: The top lever is push to lock, push again to unlock and can activate one or two lockouts. The lower lever is removable and activates the the dropper post like any other dropper remote. Retail is $120. Your Trek dealer can order it for you. I'm not sure why there is no mention of it anywhere outside of their dealer site since it doesn't appear to be under embargo or anything. It seems like a great solution if you want to replace your twist lock or other remote lock out while still running a dropper remote under the bar.
Is it? I have a grip 32sc lock/unlock fork with a twin lock and each click does something. Middle/pedal mode is stiffer than open.It's a different damper.
It is not.Any idea if the Bontrager remote is I-spec/MM compatible?
