Yeah, I'll talk to the builder but I'd still like to consult with the brain trust on this forum.
So here's my issue: Ti frame with EBB used to tension a Rohloff hub linked to a Ritchey Logic crank using a square spindle Shimano bottom bracket. The crank/bb is important as it provides the narrowest Q-factor I can find (154 mm) that also matches up with the Rohloff chainline (54 mm). I've discovered that sufficient tension to prevent slipping using either of two Bushnell EBB's or a Carver EBB will bind the bearings of Phil Wood (severely) or Shimano (moderately) bottom brackets. Add to that the creaking that comes along with the first hint of moisture or a month or so of dust -- it's driving me batty! I notice that the EBBs need to be expanded pretty extensively to lock things in place and wonder if that could contribute to the binding and chronic creaking. Could the EBB be resized (shimmed?) to counter that effect?
I expect if I was willing to go to an external bearing bottom bracket, I could at least get rid of the issue of binding the bearings, but I need to keep the Q-factor where it is or (ideally) reduce it further -- and I have to be within at least 2 mm of 54 mm to keep the chain line with the Rohloff hub.
Love to hear some ideas!
