At Tscheezy's urging, I ran some data on the Linkage V2 program- www.angelfire.com/jazz/linkage/ for the following Turner frames - 5 Spot, XCE, Burner and O2. There are also charts for the Burner with the XR rockers. I have the O2 with XR also but I'm at my upload limit.
To understand the charts, the blue line represents the compression of the rear shock as the rear wheel travels vertically. The red line shows the progression rate of the suspension as it compresses the shock. If it moves up from left to right, you have a rising rate suspension. Horizontal line means a linear rate, and a line falling from right to left means a falling rate (duh).
Rising rates mean the suspension must push harder and apply proportionally more force to the shock as it moves through its stroke to get the same amount of travel (the rate of energy input required to compress the shock rises throughout the stroke). Linear suspensions are just that, consistent through the stroke - a 500lb spring needs 500lbs to compress it one inch. To compress it another inch, you add another 500lbs (1,000lbs to compress 2 inches, etc). It's a linear progression. Falling rate suspensions increase the amount of energy applied to the shock as it moves through the stroke (less energy input needed to compress the shock the same distance).
Falling rate suspensions work better with rising rate (progressive) air shocks since these shocks need more energy/force to compress them the farther into the travel you go. Generally speaking, rising rate or linear suspensions work well with coil (linear) shocks since these designs prevent the coil from over-compressing and blowing through its travel at the end of the stroke. l Thought you Homers might like to see this information for selecting shocks, discussions around the water cooler, or after a few too many beers.
