If it fits...
I say Burner all the way. It's not only much cheaper but also a much better suspension design. I rode a Superlight for a year and a half and will tell you the single pivot is not low maintenance. The rear end is flexy which causes the shock bushing to wear. If you don't keep on top of it, you can crack the pivot bearings. I did it twice. For some reason, SC doesn't believe in replaceable derailleur hangers. So if you blow out your derailleur, strip and bend the hanger, you could be looking at a new swingarm. Yes, this happened to me as well. I might just have been unlucky with my SL but nevertheless, stuff happens. Then there are the inherent design quirks of a high single pivot like brake induced suspension lockout, pedal kickback, and overall semi-active design. Mine was also a bit slack with a 4" fork but I think they have fixed that with later models.
The design may be licensed from Specialized but the Turner is much better. A well executed 4 bar Horst bike like the Burner will be fully active and provide much more traction than the Superlight especially on technical climbs and while braking. The Turner grease ports should make for easy maintenance. They come with a platform shock so pedal bob isn't a problem. The Burner is a very good frame and a killer deal right now.
