I weigh about 190-195 with all my gear on. I was told to set it at 50lbs less than my weight. I also have the AVA in the most linear setting. I've done two rides and so far so good.JTBAZ said:I just purchased a FOX AVA propedal for my 5 Spot. I weigh 200 lbs and I am wondering how others have "dialed-in" the FOX AVA propedal. Thanks
I recently sold my Burner and purchased a 5 Spot. I was able to get a really good deal on a 5 Spot frame. I also have a HH 100X and the Burner had a very similar feel to the HH 100X - so I figured I would get something a little bit more plush.lushmd said:Hey JTBAZ, I thought that you had a Burner. Did you recently upgrade to a 5-spot? If so, why? Also, how does the Burner compare to the 5-spot? I only ask as I am considering either building up a Burner or spending a little extra and perhaps going with the 5-spot. Take care.
