Start checking out pics of various setup from the databaseSteve5S said:
http://forums.mtbr.com/showthread.php?t=27489
You should be able to find your answers.
Also, check out the Cable Routing button at Turnerbikes dot come
Start checking out pics of various setup from the databaseSteve5S said:Can anyone advise of the length of the rear gear cable outer on a medium frame 5 Spot. The sections in question are;
1, Where it goes from the top tube cable stop, through the gusset to the cable stop on the rear swing arm.
2, The loop from the derailleur (XT) to the cable stop on the rear swing arm
Thanks :thumbsup:
You could have used those tires on Indiancactuscorn said:not that s works didnt have a good idea but ya may end up seein mistakes and answers both. this is my flux before i added a rollamajig which i highly reccomend for shimano ders.
youll see a piece of housing accross the rockers thats smooth, unkinked or over stretched. note my routing is different than that reccomended by turner. some protective tape such as a thick and elastic frame, ski or helicopter variety works well. otherwise youll cut through the housing and/or rub the crap out of the frame.
youll also see another piece to the rear der thats also without kinks or excess bends. it looks long but its in fact the perfect length to rid the system of drag. the easy way to gauge length is to insert the housing with a ferrulle into the der then mock it up to the lower shock stay stop payin close attention to when the housing is a perfect 0 deg in the der stop. cut at the shock stay stop when this is achived.
i also highly reccomend dry cables and always use alloy ferruells when using 4mm housing. plastic ones bend, kink and crack creating drag. drag is bad. dont forget to use a good quality housing cutter and carefuly poke the housing open with a scratch awl after cutting.
I'm sleep deprived right now, so I need clarification on CC's comment.big_olly said:...when you say "i also highly reccomend dry cables" do you mean don't grease the shifter cables? I usually apply a small amount of grease to the cable before inserting (I mean a really small amount, just enough to say there's grease on it)...
i generally agree with the dry assessment. there's a few areas of my stumpjumper (under the bottom bracket namely) that tend to really get wet though. i usually run some finish line cross country on the cable, and then wipe it off with my fingers. just leave a tiny film of lube. my logic is corrosion resistance.cactuscorn said:in all but the wettest of conditions or those who feel a need to use older cables and housing, i say no lube. ive tried both in super dry deserts and wet/cold forests and my take on this is the newer stuff is so good its inner liner and smoother stainless strands dont need it. addin lube or grease attracts dirt and dirt kills performance. the id/od id just too tight for any addition of masses of outside particals or heavy fluids. many will dissagree.
No CC, he's talking about his current ride. I believe its like my 04 Stumpy, it has the RD cable running underneath the downtube, and then it makes a funny loop under the BB shell to the chainstay.cactuscorn said:no lube. ill refrain from jokes or further comment.
if wankers talkin bout down tube routing, specially such as old stumpy h/t's without housing, this makes tons of sense. i did the same thing with my '93 and '97 stumps. the old finishline xc lube was a good choice in its day but theres better now. for wet days theres none higher than rock n roll blue with boshield and a few others right behind.
