1 - 4 of 4 Posts
· Registered
I'm looking for some advice on tuning in the front der. on my new DT running 2x9 w/bashguard. I'm having issues with front der rubbing when I'm in my outer and inner gears. So for example if I put the cable tension in the middle I get rub in 2-1,2-2 and in 1-9, 1-8. If I tighten the cable it takes away the rub in on the 1-9, 1-8 side but then it rubs in 2-3, 2-4. The same thing happens if I go with less cable tension. All of my limit screws are backed way off so that's not the issue. I noticed the shifting seems to be perfect on the stand but when I sit on the bike the sag makes a different part of the der hit the chain. Any ideas?
1 - 4 of 4 Posts
