Ok so I've got my new Z-1 light but have a few tuning questions. I weigh 165-170 with riding gear and I'm running the fork at 130mm travel. With the air preload set at 20 psi I get 1" of sag however on a ride or bouncing up and down on the fork as hard as I can I'm only getting about 105mm of travel. Compression is set about 2 clicks in from full soft, rebound is set at 5 in from full fast.
I haven't opened the fork up yet to look at oil levels, I can't find any information on the Marzocchi web site about oil levels for this fork. If I lower the preload air pressure I get more travel but too much sag and the fork is more prone to blow through travel.
So my thoughts are:
A. Raise the oil levels so I can run lower air pressure but still get the correct amount of sag and decrease the ramp up.
B. Lower the oil level and possibly raise the preload air pressure to get correct sag while decreasing ramp up.
C. None of the above
I don't know if Marzocchis are prone to not having as much usuable travel as they claim ( like the Fox Talas I replaced) so maybe the set up is fine and I just won't get much more in the 130mm setting. The quality of travel is good even though the fork isn't broken in yet.
Thanks for any tuning tips
So my thoughts are:
