I have a Nixon Super fork and a Swinger Air SPV 4-Way rear shock.
The shocks seem to have been delivered underinflated (which I'm assuming is the norm in delivery), and the bike shop that put together the bike and tuned it for me did not do any shock adjustments. They did not even have a shock pump on hand (last time I go there - great with road bikes, not mountain).
So I plan to buy a Manitou shock pump (or will any do?) and make adjustments. From the PDF from the instruction manual, it seems as if they suggest adjusting PSI to sag distances for the fork. Is this the best way to go? I am 175 pounds for reference. As far as the rebound and compression adjustments on the shock, I am a bit lost in what those should be set to. I am doing mostly XC right now.
The rear shock instructions say inflate the red SPV chamber to 75psi, then adjust the rest using the sag method. Rebound/compression to preferences.
Any suggestions? Would it be a better idea to take it to a good shop to have them fine tune it for me?
I am an air shock newb, so advice is appreciated!
