I see lots of tire threads so I thought why not 1 more.
These are tufo thundero 40mm tubeless ready tires. I installed them in June and replaced the rear today after 3100 km/1900 miles. This is roughly 1/3 gravel/dirt/forest roads and the rest roads. They stay on for my commute.
Overall impressions are great. I use tubes. Easy to install and had no issues seating on 21mm internal width rims. Both new Rear and old front measure 38mm, 40mmlug to lug. Tread depth is 2mm, the old front is worn 1/2 way, rear is almost gone.
I’ve found the ride quality to be excellent. Very subtle tires, almost as nice as my compass grand bois tires. The side lugs are offset enough that they don’t affect cornering on asphalt. Grip well in the rain. A quiet tire and fast. On dirt, hard pack and country roads they corner well, lugs hold in hard cornering but close enough spaced they don’t shudder. Confident braking and grip well under load and speed.
I’ve had 1 flat and that was on the rear last week.
Only area where they suffer is mud.
For tires I bought for $41Can, was more than impressed. Enough that I replaced the rear without thinking of a different tire.
1st pic is old rear vs. new
2nd is used front vs. new.
