So after running tubulars for a few weeks now I have learned a few things about them:
First, the bad: Tufos tape alone is NOT sufficient, even when installed properly with a tire made specifically to be used with it. I rolled a tire on a high speed, off-cambre corner near the end of a race. Luckily the tire was undamaged and the rim sustained only a tiny scrape before I slid safely into the grass, and I managed to remain upright. Tape remained intact on the rim but cleanly detatched from the tire, which was wet underneath. My hypothesis is that water from torrential rain and creek crossings may have been wicked under the tire by way of the cotton base tape and/or casing and reduced the bonding strength of the tape to the tire. Combined with the increased leverage of a large-volume tire at low pressure, the bond was obviously inadequate. Tufos tape may still be adequate in completely dry conditions, but after my experience I am now unwilling to risk it.
The problem was clearly between the tape and the tire, not between the tape and the rim. I have since learned that the tape is used often by cyclocross racers as a first layer on the rim before using glue as normal to facilitate easier cleaning/removal when changing tires, which I will likely try in the future. For the time being, having had the tires properly glued I can now corner hard at low pressures with no fear of rolling a tire.
Which brings me to the good: performance of the tire- almost independent of size and tread- is outstanding on nearly any surface (barring clingning mud, which I've been fortunate to avoid so far). I attribute the performance more to the tubular technology than to the tire tread. I went from relatively knobby GEAX Saguaros with generous volume to much smaller and less knobby Tufos XC2 tires, yet still experience huge benifits in cornering and overall comfort when compared to clinchers. The larger heavier tires were better overall, but the smaller, lighter tires are still damned great. I would not trust the same tire as a clincher and strongly doubt that it would perform nearly as well, especially when pushing hard into a corner on rough terrain. Even with the small tires, I can lean the bike into off-cambre corners with confidence I would never have on a clincher XC race tire.
Other than the tape failure, reliability has been fantastic and the wheels themselves are amazing. Running sealant in the tires, I have not had any issues with flats. The overall weight reduction of the system is substantial compared to even the lightest clincher rims. For XC racing, I think tubuler MTB are certainly becoming a viable option.
Finally, I got some reliable intel that interest is increasing in the industry and that several major companies are working on MTB tubular tires and rims for next season, which is great news. I can't wait until there are a few more higher-volume tires available from some of the brands we all know and love.
