I'm not familiar with that rim, but it depends on how the tire you choose will seat on top of the rim tape... If it's too loose, you need the rubber strip, some rims you can use just the yellow tape.
You might consider a Stan's rim if they have one that will fit your needs. They have been by far the easiest to go tubeless, since they are made for that purpose. Now that I've had Stans rims and Stan's conversions I really dislike converting a wheel and having to use the HEAVY rubber strip in most cases.
Also looks at the Stan's site, they list a lot of rims and whether or not you need to run a ruber strip, yellow tape or what ever.
On some rims they say to leave the original rim tape on and then put the rubber strip over it.... UGH Heavy!
Is this the rim you are looking at? http://www.beyondbikes.com/ItemMatr...utm_medium=GoogleProduct&utm_campaign=Froogle
You might try Stan's rims spec's here: http://www.notubes.com/ztr_rims.php
Do some snooping on Stan's site... I've been very pleased with all 4 sets of my wheels...
I'm sure you'll enjoy tubeless if you go about it properly and the lower air pressures you can run are awesome! I run 22/24psi Ft/Rr - sweet!
Hope this helps!
Hope this helps!
