I woould...and did.wasatchbiker said:
If you get a flat you just pop in a tube and away you go...
BUT you will get a lot less flats with tubeless and even just a touch of sealant....
If you are prone to pinch flats, ride lots of sharp rocks or get into thorns, then it is almost required to get into tubeles to acheive the wide tire low inflation pressures that lead to low rolling resistance, and flat resistance.
Both of which are a premium for endurance racing.
In 2007 I would say easily half of the Trans Rockies was on tubeless....winners wore tubes I think though.
