eatdrinkride said:
If you want to run ghetto style tubeless be prepared to make a career out of it. At least at first.
Ghetto tubeless is not exactly rocket science. Anyone with a small amount of mechanical skills can easily do it.
1. Drill out the Crossride valve stem hole so a schrader tube fits.
2. Get a cheapy $3 Pyramid 20"x2.0 schrader valve tube.
3. Cover the spoke holes with a standard rim strip, rim tape, or a couple layers of strapping tape.
4. Inflate the 20" tube slightly, insert the valve stem and evenly stretch the tube around the rim.
5. Using EMT scissors cut the tube all the way around, splitting it down the middle. (Pyramid tubes have a nice little seam to follow)
6. Use a wet rag to wipe off all the talcum powder that was inside the tube.
7. Make sure the tube is evenly flapped over the sides of the rim, all the way around.
8. Install one bead of the tire all the way on, using your hands. Avoid tire levers.
9. Install the other bead most of the way, then add 2 scoops of Stan's sealant.
10. Finish installing the last part of the bead(by hand if possible, most tires can be)
11. Make sure tire is on good and inflate to 35psi.
12. Hold the wheel at the 3oclock, and 9oclock spots and shake the tire side to side splashing the sealant up the sidewall of the tire. Rotate one spoke hole and shake. Do this all the way around the tire, giving a second or two for the sealant to go to the bottom between shakes.
13. Carefully pull the excess tube outwards and trim all the way around with an exacto knife. Don't worry about getting real close, a little bit of rubber sticking past the rim does not hurt a thing.
14. Set your pressure and ride. I run 25psi in a Geax DHEA front tire, which is a big 2.3 tire, more like a 2.5. I run 27psi in my Minion DHF on the back. It is 2.3, but more like a 2.2. This is on very rocky Arizona trails. Here, sealant dries out in a couple months in the hot summer, but in your neck of the woods will probably last till the tire is toast.
Couple tips. Kenda tires can be hard to seal, and some say that sealant degrades them. Avoid them for your learning. If you ride lots of rocks, don't go with paper thin sidewalls. If a tire is high volume, and light, guess where the weight savings came from? Probably the sidewall. Tires I have had good success with the sidewalls in rocks are Geax tires, Maxxis Minions, Panaracer Rampages, and even wire bead Velociraptors. Don't waste money on CaffeLatex, Stan's works just as well and cheaper. I am making my own sealant with mold builder/auto slime/antifreeze/water. It works well too and is the cheapest of all. After a couple times it will take you all of 10 minutes to do a tire. Good luck.
