1 - 8 of 8 Posts
I'm running Mavic Crossland UST wheels with Hutchinson tubeless tires. I love the setup when riding; no problems. However, I always have to fill the tires before I ride. If the bike sits for a week ( I know, blasphemy) the tires go all the way down. Never been a problem so far on a ride but in 5 or 6 hours I might have to refill.
I really don't want to use Stan's or Slime. Does anyone have a tire on Mavic wheels that holds air?
LA CHÈVRE
Yes. I had a set of tires mounted and the spare wheelset was sitting in a room for about 9 months and they barely lost pressure. No sealant but you shouldn't expect that.
If they go completely flat in about a week, check the bead condition, make sure the rim is clean before you put on the tires and check that the valve doesn't leak (tub test). If they leak through the casing, well, you either have to deal with the pre-ride re-inflate or use some sealant. Hutchinsons usually hold air very well.
Discussion Starter · #7 ·
I have tried the over pressure thing a couple of times to seat the beads. I think that is fine. I will reset the valve stems with grease (I think they may be dry). Hope it's not the rim strips because both wheels have the same problem.
1 - 8 of 8 Posts
