jcdawes said:
Dude, that looks like a lot of work. One question: Not sure what the soap is for. You'd think that it would be harder to get sealed that way. How much do you think a bike shop would charge you to do all that? Also, how much are the conversion kits?
Thanks for the info.
Late,
Jeff
Actually the Stan's and other DIY tubeless setups aren't that tough as long as you have the right rim and tire combo. If you are running wide (freeride style) rims, you will have a tough time getting 2.1 tires to inflate. If you go with 2.3s it will be much easier. The soap is not always required. In the Stan's installs I have done, no soap was ever needed but in my installs, only UST tires were used.
If you go the Stan's route, you should consider sticking with UST tires only. Doing so will save some pain during the install/inflation. Also, most of the bad reviews you read about Stan's are people trying to use standard tires.
For the Nomad, you should probably look at something bigger than a 2.1 tire. The Continental Vertical comes in a 2.3 UST model. Unfortunately, there are very few 2.3 and larger UST tires at this point. I don't really get this because it seems to me that trail and free riders stand to gain the most from tubeless.
Lastly, even if you use UST tires and UST rims, using sealant is still something to consider as it can give an extra bit of flat protection from punctures. As for on-trail flats (which are much fewer than running tubed), just take a tube with you. If you flat, you just pull out the rim strip or UST valve stem, put in the tube, and air up to get you home.
